Raw Hex Support
Hi Salae Community,
often times I need to view raw data coming from rf chips.
Therefore, I would need support for a protocol with
8 data bits and no start, stop or parity bits.
I want to be able to use Async Serial with 0 stop bits,
to view the RF data in HEX.
Thank you very much for any suggestions or replies!
Niklas from :austria:
@niklasprobst11 Thanks for reaching out! My first thought is that a custom solution may be required using our Protocol Analyzer SDK (perhaps using our Async Serial analyzer as a starting point).
Our Async Serial analyzer does in fact require a start bit to signify when to begin decoding data for each word being decoded.
Is there a set cadence or known delay between transactions for the data you are decoding? For example, how does the receiver align with the incoming data without a start bit? Is there perhaps a clock signal? Hope to learn more!
