I have installed pip install logic2-automation Salaea package and want to use extension clock_stats.py. This feature requires from saleae.range_measurements import DigitalMeasurer. However Salaea python package does not contain package for range_measurements. I get error ModuleNotFoundError: No module named ‘saleae.range_measurements’ Where do I get from saleae.range_measurements implementation.
Thanks and Best
Khulan
Hi @khulan.bayarsaikhan ,
Sorry for the confusion - the logic2-automation python API is separate from our measurements API. The measurements API is only accessible from a script running within the Logic 2 application.
If you are looking to use the clock stats measurement directly, without modifications, you can install it from the Extensions Marketplace:
If you want to use a modified clock_stats.py, you will need to load the extension from within Logic.
The documentation for extensions (HLAs and Measurements) is available at https://support.saleae.com/extensions/extensions-quickstart
Hope that helps, and let me know if you have any other questions,
Ryan
Hi Ryan,
This extension is installed. However, it is not listed on python pip package, which I need for automation.
Best regards
Khulan
Unfortunately measurements are not available from the automation API. If you can provide more information about your use-case I can try to offer alternatives.
Ryan
Hello i would like to see if there’s any update regarding this issue as im facing something similar
@sura.al-fuqaha Measurements via our Automation API is currently not available. However, we’re tracking this request in the link below! I’ve added a comment for you to track your need for this as well.
