I need to capture eight digital channels at once with the “Logic MSO 4x100” through the Python MSO API, so I have to use two ports. For testing purposes, I run the following code with only two digital channels from different ports set up:
scope = mso_api.MSO()
save_dir = Path('SaleaeLogicMSO-Capture')
scope.capture(
mso_api.CaptureConfig(
enabled_channels=[
mso_api.DigitalChannel(port=0, channel=0, threshold_volts=2, name='P0_CH0'),
mso_api.DigitalChannel(port=1, channel=0, threshold_volts=2, name='P1_CH0')
save_dir=save_dir
Running this code throws following error:
[capture_commands.cpp:77] exception during recording: invalid map<K, T> key
The capture_stdout.txt is attached.
The same error occurs trying to capture all eight channels. Individually capturing channels of port 0 or 1 works, so it doesn’t seem to be a hardware error.
capture_stdout.txt (15.4 KB)
