we have several years experience with Logic analyzers and we now got the MSO be able to measure analog and digital together. Using an extra scope makes timing measurements always difficult.
It seems the hardware is very capable but the software needs some tuning.
Since the digital single shot feature did not yet make it into the MSO software (at least not as comfortable as on the Logic versions) we were using the analog input as a trigger. Long story short, it did not work that well.
We hocked up one analog channel to the 1 kHz reference clock to create a trigger signal while also capturing two digital one.
This seems similar to my post (issue #2:One Shot Trigger Problems) … you might be able work around the one shot trigger issue by extending the holdoff, as long as your capture buffer/transfer time is less than the holdoff time. If sampling at maximum sample rates and capturing multiple channels, you might not be able to get it to trigger & stop.
Meanwhile, regarding:
… are the gaps all ~12ms wide at start of capture?
Came here to say that the 12ms digital channel issue is causing issues for our small fleet of MSOs that we’re evaluating where I work. Overall, I’m surprised that the MSO seems to suffer from a major feature regression compared to the Logic Pro line wrt digital captures.
We just shipped 2.4.48, which contains a fix for the gap in digital channels that occurred every time the channel was enabled. That release contains a large number of other fixes too.
Please update and let me know if you are still experiencing issues!
