Logic MSO: saleae-mso-api 0.5.8 capture fails on macOS (Apple Silicon) at ScPdProcessingEnable, but Logic 2 works on the same machine
Hi all,
My Logic MSO works fine in Logic 2, but every capture through the saleae-mso-api Python package fails during device initialization on macOS. Posting the details in case someone has seen this or Saleae can point me at what’s different between Logic 2 and the SDK’s recorder.
Summary
  • mso_api.MSO() connects and mso.part_number returns correctly.
  • Any mso.capture(...) then fails after about 60 s with MsoCommandError.
  • In the recorder log, initialization reaches 100% (firmware, FPGA, DDR, ADC and JESD all succeed). The failure is the last step: MsoDeviceInterface::SetEnabledSmartCablePorts, which sends ScPdProcessingEnable, enabled=0x1f, disabled=0xffe0. That USB control transfer fails with:
    • [0xe00002eb] (iokit/common) operation aborted; DeviceRequestTO failed (first cable), or
    • [0xe00002ed] (iokit/common) device not responding; DeviceRequestTO failed (second cable).
  • The bulk read stream then aborts, the device re-enumerates (Device connected while awake), and the recorder reports Failed: 'MSO not ready'.
Environment
Item Value
Device Logic MSO, MsoPod_2ch_100Mhz_9b_100Ms
Boards MsoMain_1_5_GB Rev0B; AFE MsoAfe_2ch_9b Rev0E
Firmware 1.1.0, build date Nov 12 2026, info 76f1ac3 (the SDK logs “Firmware is up-to-date”)
Host macOS 27.2.1, Apple Silicon (arm64)
Python 3.14.7 (also tried 3.12 with 0.5.6)
SDK saleae-mso-api 0.5.8 from downloads.saleae.com/pypi. 0.5.6 fails identically. 0.5.0 and 0.4.0 have no macOS build.
Logic 2 2.4.50, quit completely before running the SDK. The MSO captures normally in it on the same machine, port and cable.
USB Enumerates at 5 Gb/s. The recorder reports a 20 V / 1.5 A supply and “PD contract established”.
What I’ve ruled out
  • Logic 2 holding the device (fully quit; with it open I get a different “exclusive access” error)
  • Reboot
  • Plugging the scope directly into the Mac, no hub or dock
  • Two different USB cables
  • With and without a probe on channel 1
  • Capture settings: defaults, settings matched to Logic 2 (AC, 1x, 2 V range, 12.5 MS/s, 100 mV rising trigger, 10 ms window), and a 1 s TimedCapture
  • The unmodified example from the Getting Started guide fails the same way
  • Firmware: reported up-to-date by the SDK itself
Reproduction
from pathlib import Path
from saleae import mso_api
mso = mso_api.MSO()
config = mso_api.CaptureConfig(
enabled_channels=[mso_api.AnalogChannel(channel=0, name="clock")],
analog_settings=mso_api.AnalogSettings(sample_rate=100e6),
capture_settings=mso_api.TimedCapture(capture_length_seconds=0.1),
mso.capture(config, save_dir=Path("my-captures") / "00") # fails after ~60 s
Questions
  1. Is saleae-mso-api 0.5.8 supported on macOS 27 / Apple Silicon with the 2-channel 100 MHz MSO? Which OS and SDK versions have you validated?
  2. Is firmware 1.1.0 (build Nov 12 2026) the version 0.5.8 is meant to work with?
  3. Why would the ScPdProcessingEnable control transfer succeed in Logic 2 but time out in the SDK’s mso_data_recorder?
  4. Is there a debug option or environment variable to get more detail from the recorder?
  5. Is the logic2-automation 1.2.0 headless preview with MSO support the recommended path on macOS while mso_api is being replaced?
Full recorder logs are attached (device serial, board IDs and my username redacted; the repeated DDR polling lines are collapsed and marked):
  • log1_raw_sdk_capture.txt: raw SDK capture (1 MS/s, 4 V range, 0 V rising trigger, 1 ms window)
  • log2_second_usb_cable.txt: settings matched to Logic 2, second USB cable
  • log3_getting_started_example.txt: the Getting Started example, unmodified
log1_raw_sdk_capture.txt (21.0 KB)
log2_second_usb_cable.txt (20.8 KB)
log3_getting_started_example.txt (20.6 KB)
Hello @mike.trimborn,
Sorry for the trouble with this! This is our fault, and it’s fixed now. Details here: Saleae-mso-api 0.6.0 & Logic 2 2.4.50 Logic MSO firmware update
TLDR:
  1. saleae-mso-api was not firmware version aware. It did not validate that the attached Logic MSO was running compatible firmware, and the latest Logic 2 software included a breaking firmware update.
  2. It took us several extra days to get the saleae-mso-api update out. Version 0.6.0 fixes the issue, and adds straight forward exceptions for firmware version compatibilities.
Updating your saleae-mso-api version should fix it.
