I recently purchased a Logic MSO. I was impressed with the industrial design, build quality, user interface, and overall attention to detail, but I was disappointed in the lack of functionality of the oscilloscope. Features that are available on less expensive Chinese oscilloscopes, such as those from Siglent, are absent in the MSO. For example:
- There are no math functions.
- There is no FFT.
- There is no intensity grading (aka “virtual phosphor”).
- There is no X-Y mode.
- Only rudimentary trigger conditions are supported.
For me, the saving grace is the extensibility through APIs, but I do hope that these shortcomings will be addressed in future updates.
@watkins.robert Sorry about the missing features you’ve listed, though, I’m glad to hear you’ve been enjoying other aspects of our Logic MSO so far! This feedback is helpful.
I can say that math channels and FFT are on the list. Having said that, I can’t provide a timeline as to when we’d be able to start working on these. We’ve got a couple other projects lined up beforehand. Also, FFT and XY mode are both things that we would like our python measurement API to support, even if we build first-class versions of these features as well.
For intensity grading, are you looking for something eye-diagram like (e.g. persistence view + either edge trigger)?
Also, what kind of trigger conditions would you be interested in using?
We’d love to learn more about your use cases!
Thanks for the response, Tim. I’m glad to hear that you are working on some of these features.
For intensity grading, I’m looking for something that (optionally) emulates an analog scope. I would like to see faster transitions, such as the edges of a square wave or the higher-amplitude portions of a modulated AM carrier, displayed with less intensity.
Check out the user manual for the Siglent SDS2000X series for a list of trigger conditions that they support. Of these, I’m mainly interested in the ones that detect anomalous conditions: Runt, Dropout, and Interval — possibly Slope as well.
Aside: I’m glad to see that one-shot will soon be supported for digital triggers. In the meantime, I noticed something that appears to be a bug. I monitored the same signal with both a digital and an analog channel, and I triggered on the analog channel. This worked fine as long as I kept the (redundant) analog channel visible. If I hid it, the scope failed to trigger, even though the channel was still active in the Device Settings sidebar and set as the trigger source in the Recording Settings sidebar.
Of these features, I think that math mode with FFTs would be a big win. Currently, I export using binary format and then import that into Julia in order to do the math I need and then plot it out again. It works and is fast, but there are a fair number of manual steps.
What would be fabulous is to be able to program the transformations directly. Python is a poor language for this since I would have to resort of numpy for essentially every computation as opposed to having a high performance language like Julia, but it could work. The ideal would be to allow vector functions that could define virtual traces from existing traces. You could define some functions that could be set up through the GUI and we could define a bunch more.
I also noticed that the Logic MSO doesn’t do sin(x)/x interpolation. The plots below show a 160 MHz signal as captured and the same signal with interpolation applied in post processing.
I am looking for hardware for my next 'scope. I have long believed that acquisition hardware should be complemented by open source or extensible display software and fixed signal processing will eventually be obsolete.
Logic MSO is clearly a candidate for the hardware and my experience with Logic tells me Saleae will strive to produce excellent hardware and software.
However,. it’s clearly a long road to get to the feature set you want to provide and the extensions from there.
There is already an impressive platform in the form of ngscopeclient. It supports a reasonable number of existing hardware platforms but most have compromised connection performance as they are display oscilloscopes first and foremost. Exceptions are Pico and Thunderscope, comparable roughly with Logic MSO.
ngscopeclient provides FFT, protocol analysis etc. and it’s likely that it will be popular as a platform for many other specialist signal processing applications.
How would a Logic interface to ngscopeclient best be implemented ? Could it be done using the existing Logic APIs or would it be better with a custom device layer that skips the python interface ?
I understand that ngscopeclient has specifically been written with a non-GPL licence. Although this disappoints me somewhat it is there so that interfaces can be supported by manufacturers without making their proprietary components open source, so it may be especially suited for support by manufacturers.
Yes, please implement the FFT and MATH features.
