2.4.42 Download Links
2.4.42
Welcome to the 2.4.42 release of Logic!
This release also includes a required firmware update for Logic MSO devices.
What’s New
- Added undo / redo for viewstate navigation, allowing the user to quickly step back to previous zoom and pan settings. You can use the back button on your mouse, or alt+left/right arrow on Windows & Linux, or command+left/right on MacOS.
- Improved the display of the vertical voltage rulers for Logic MSO. they now take up less horizontal space.
- Improved the off-screen and out-of-range signal display for Logic MSO. When the signal is off-screen, it is displayed as a dashed line at the extent, but if the signal is out-of-range, it will display as a solid red line at the extent.
Fixes
- Fixed issue when running two different versions of Logic 2 at the same time.
- Fixed issue where if you unplugged a device while it was still connecting, the connection notification could get stuck open.
