NOTE: We are seeing some issues with this version where the app doesn’t load correctly, we have removed this as the main download. Any info you can send that could help us figure out this bug will be greatly appreciated. You can email us at support@saleae.com or post to this topic.
What’s New
- We have upgraded to Electron 15. Please let us know if you have any issues by emailing us at support@saleae.com
- Added ability to select multiple measurements and timing markers using Ctrl-A. You can also use Ctrl and Shift click to select multiple elements in the right side bar.
- Fixed issue where jump to edge and bubble icons would not appear nor would the shortcut work in certain situations
- Fixed issue where timing marker comment box would cover up right click context menu
