My guess would be you might be having some USB intermittent issues. Does it happen if PC stays ‘busy’ (i.e., actively using PC keyboard/mouse while script is running vs. console is essentially ‘idle’ other than the script?) Does the Logic 2.exe process hang/crash in Task Manager?
Quick tips:
- Make sure the Logic is only device on USB, if possible
(no other USB devices connected/in use) - Make sure PC is on AC vs. battery power
(set on full/high performance, not battery/lower power optimized) - Make sure USB port won’t go to sleep
(Turn off all USB power saving options, so ‘always on’ and Windows won’t disable/power off port) - Try the same script on a different PC (if possible, a different model) and see if you get the same result
More possible links w/ ideas to try:
- device setup failure
Error Message: DeviceSetupFailure | Saleae Support - USB timeout (for tips on improving USB connection)
Error Message: ReadTimeout | Saleae Support - Longer page on some old/prior USB issues (seems more for Linux, but some ideas may help/apply in general or on Windows)
Device Disconnected Error
