The code below regularly crashes, if I let it run for a couple of minutes. It never reached 10min so far. I’d like to run it for a couple of hours. Why could it be that the Device Setup fails? Any suggestion would be appreciated.
Code:
dev_conf = automation.LogicDeviceConfiguration(
enabled_analog_channels=[0],
analog_sample_rate=625000,
cap_conf = automation.CaptureConfiguration(
capture_mode=automation.TimedCaptureMode(duration_seconds=T_sample)
abs_path = ‘C:\work\git\vinsontruck-python-tools\scripts\out\’
with manager.start_capture(device_configuration=dev_conf,
capture_configuration=cap_conf) as capture:
capture.wait()
capture.export_raw_data_csv(abs_path, analog_channels=[0])
ntc_dat = pd.read_csv(abs_path + ‘analog.csv’)
ntc_u_arr = ntc_dat[“Channel 0”].to_numpy()
u_mean = np.mean(ntc_u_arr)
u_std = np.std(ntc_u_arr)
return (u_mean, u_std)
Error (last view lines of terminal ouput, the two numbers are just u_mean and time):
INFO:saleae.automation.manager:sub ChannelConnectivity.IDLE
INFO:saleae.automation.manager:sub ChannelConnectivity.CONNECTING
INFO:saleae.automation.manager:sub ChannelConnectivity.READY
2.72
487.97
2.72
496.55
File “c:/…/scripts/MWE.py”, line 44, in
(u_ntc, std_ntc) = getNTCu(T_sample_ntc)
File “c:/…/scripts/MWE.py”, line 17, in getNTCu
with manager.start_capture(device_configuration=dev_conf, capture_configuration=cap_conf) as capture:
File “C:.…\lib\site-packages\saleae\automation\manager.py”, line 583, in start_capture
reply: saleae_pb2.StartCaptureReply = self.stub.StartCapture(
File “C:\Program Files\WinPython38_64bit\python-3.8.6.amd64\lib\contextlib.py”, line 131, in exit
self.gen.throw(type, value, traceback)
File “C:.…\lib\site-packages\saleae\automation\errors.py”, line 121, in _error_handler
raise grpc_error_to_exception(exc) from None
saleae.automation.errors.DeviceError: Error interacting with device during capture: DeviceSetupFailure.
I am using windows 11, Python 3.8.6 in VS Code 194.0, Logic 2.4.14, Logic 8 hardware, USB cable directly connected to mainboard of laptop, I tried both laptop USB ports
Thank you for your help
