The first time I execute the following script after starting up Logic 2 program , the code below works as expected. The second time it blocks forever in the add_analyzer block. What could be the issue? Thanks!
cls.manager = automation.Manager.connect(port=10430)
enabled_digital_channels=digital_channels,
digital_sample_rate=digital_baudrate_hz,
enabled_analog_channels=analog_channels,
analog_sample_rate=analog_baudrate_hz,
#digital_threshold_volts=3.3,
if capture_seconds is None:
#capture_mode=automation.TimedCaptureMode(duration_seconds=5.0)
else:
capture_mode=automation.TimedCaptureMode(duration_seconds=capture_seconds)
cls.capture = cls.manager.start_capture(
capture_configuration=capture_configuration)
cls.capture.stop()
# Gets blocked below the second time: ##
analyzer1 = cls.capture.add_analyzer('1-Wire', label=f'test', settings={
'1-Wire': 0,
print("2")
spi_analyzer = cls.capture.add_analyzer('SPI', label=f'WASKA', settings={
'MISO': 0,
'Clock': 1,
'Enable': 2,
'Bits per Transfer': '8 Bits per Transfer (Standard)'
capture_filepath = os.path.join(cls.output_path, 'example_capture.sal')
cls.capture.save_capture(filepath=os.path.abspath(capture_filepath))
cls.capture.remove_analyzer(analyzer1)
cls.capture.remove_analyzer(spi_analyzer)
cls.capture.close()
cls.manager.close()
