Compact headers / harnesses
hi, i’ve been looking at alternative cable harnesses for the logic pro 8 & 16
are there any off-the-shelf options out there? like a finer pitch in the other end, possibly combine 2x 4x2’s into one 10-pin header (8 signal + 2 gnd). thoughts?
(aware that you can get any made via digik and lcsc)
@janny-bb Though not exactly what you’re describing, these options below available from us are the best options for interfacing Logic analyzer channels to other pin headers/ports.
In case you wanted to make your own custom cabling, our dimensions and header/crimp part numbers can be found below for reference.
thanks! any plans to make some more compact wire-harnesses in the future?
like 4x2pin from logic → 1.0mm pitch picolock or similar
@janny-bb We don’t have any plans to release a version of our wiring harnesses that you described.
Having said that, we do sell a wire harness that has bare wires on one end so that you can solder on any connector you’d like.
