Can't add settings in the default HLA template
I’m trying to write an HLA, but even exactly following the tutorial, when it tells me to remove the example settings and add a StringSetting, I get the following error:
SandboxHla error - ValidationError('Missing setting: search_for)`
  File "C:\Program Files\Logic\resources\windows-x64\pythonlibs\lib\site-packages\saleae\analyzers\high_level_analyzer.py", line 24, in __call__
    obj = cls.__new__(cls, settings, *args, **kwargs)
  File "C:\Program Files\Logic\resources\windows-x64\pythonlibs\lib\site-packages\saleae\analyzers\high_level_analyzer.py", line 70, in __new__
    raise ValidationError('Missing setting: ' + name)
It seems like it’s expecting my new setting to have been listed somewhere else too, but the tutorial doesn’t mention adding it anywhere else that I can find.
I poked into high_level_analyzer.py, and it looks like it’s doing something with comparing the setting member name with the keys in a dictionary that it just built using its own member names so I really don’t see how this could fail.
@pgf Hm… the script along with the changes outlined in the tutorial support article you linked should just work if followed along. Perhaps an update we made may have broken something. We’ll run some tests and will report back on our findings.
@timreyes thanks for the reply. It does feel like there may be some sort of caching bug causing it to conflate expectations of settings present in the current script with older versions of the script. At one point I got an error after just deleting the default my_string_setting, etc. variables, but I wasn’t able to reproduce that one when making this post.
I will do some testing with installing fresh with various settings to see if it works better.
Hey @timreyes, just wanted to add more info for debugging: for me I had the same issue, but after deleting the HLA then readding it will run fine.
I’ve run into this myself. It appears to be caused by adding new settings to an analyzer that’s currently loaded into a capture. Upon reload, it immediately raises this exception. The workaround is to delete the analyzer from the capture and re-add it.
I would submit a bug report about this but I don’t know how to report against the Python libraries themselves (which do not appear to be part of the Saleae Github repo).
@baebiebrian Thanks for confirming that workaround! I posted the bug here and linked back to this forum thread for reference.
