Is it possible to setup the Async Serial trigger so the trigger happens when a sequential pattern of bytes is seen in a channel’s data? Example, set trigger to look for 0x08, then, 0x01?
Thanks for letting us know your need for this! Unfortunately, this isn’t readily supported by our software. However, we’ve received several requests for this in the idea post below. I’ve added a comment for you to track your need for this as well. Apologies we don’t have an immediate solution for you.
