Whats included in Logic Pro 16
Hello Team,
I am planning to buy Logic Pro 16 - can you let me know if i need to buy any accessories like cables or clips or it comes along with kit?
if i need to buy were i can buy those?
Also, can you let me know what protocol are are supported by default.
a complete set of clips and cables is included. you can buy extras on the saleae shop, too (thats for cases when you need spares because you dont want to unplug a setup or similar)
and for the protocols: you can check that out in the software in the demo mode already. all analyzers that you can select there (or install as plugin further down) work with any model
Hi @puneethsk.engineer,
Like @masterx244 said, the device comes with all the accessories you should need. The extra accessories we sell are usually for less common situations. (For example, if you want to switch your Pro 16 between different projects while leaving the wire harnesses installed, you might want extra wire harnesses).
You can find all the built-in protocol analyzers here: Supported Protocols | Saleae
Let me know if you you’re looking for a specific protocol you don’t find in the list!
Accessories for our Logic Analyzer devices here: Accessories | Saleae
