I’m writing a low-level custom analyzer on MacOS Ventura (x86) using the Analyzer SDK. I’ve followed the readme instructions and successfully renamed, built, and launched the sample analyzer. I set the custom low level analyzers directory in the Preferences dialog to …/build/Analyzers. I notice the build analyzer has a .so extension. I also enabled the debugging entitlement for Logic.
Currently, I’m unable to attach and launch the debugger. It appears lldb cannot read the built .so file:
error: symbol[257] has invalid string table offset 0x874850f in /System/Library/PrivateFrameworks/GPUCompiler.framework/Versions/31001/Libraries/libllvm-flatbuffers.dylib, ignoring symbol
warning: (x86_64) /System/Library/PrivateFrameworks/GPUCompiler.framework/Versions/31001/Libraries/libGPUCompilerUtils.dylib load command 1 LC_SEGMENT_64 has a fileoff (0x3afca000) that extends beyond the end of the file (0xa9a0), ignoring this section
warning: (x86_64) /System/Library/PrivateFrameworks/GPUCompiler.framework/Versions/31001/Libraries/libGPUCompilerUtils.dylib load command 2 LC_SEGMENT_64 has a fileoff (0x79a98000) that extends beyond the end of the file (0xa9a0), ignoring this section
[1] 58652 bus error lldb libMyAnalyzer.so**ylib...**
I tried to follow some of the troubleshooting instructions, but it very confusing. It claims the analyzer should have a .dylib, yet the sample builds a .so. I also explicitly set CMake to use Clang as its compiler.
Any ideas what may be going wrong?
