Logic Table data (protocol decoder info) doesn’t match the timestamps of the analog voltage data timings
I exported the usb protocol decoder info of a capture as well as the analog information of the same capture. I want to correlate the specific packet data with the analog voltage values using the timestamp. ZBasically I want the voltage value at a specific packet, lets say PID IN or PID OUT. But the timestamps doesn’t match.
Could you please help me with this ?
Thank you.
@mstharunreddy Can you share a copy of your capture file that shows the issue, and can you share the exact steps you take to make the timestamp comparisons? Also, what is the error of the timestamp mismatch you are seeing? Perhaps you can share a screenshot of what you are observing on your end as well.
We’ll be happy to look into this for you once you share the information above. Hope to hear back!
