Logic MSO with differential signals
Has anyone ever used differential signals with the MOS scope feature? if so, how did you do this? I have used the common mode ground and the positive side of the differential signal but I can’t do that this time. I need to capture the entire differential signal.
@jonftorr We plan to add support for differential signals sometime in the future via a differential Digital Probe!
Our recommendation at the moment is to record one end of the differential signal with respect to ground. Since you mentioned that this doesn’t work for your particular signal, you’ll likely need to use an external voltage level translator.
Out of curiosity, can you describe the voltage levels of your signal? Does it fall outside of the selectable 0.6 V to 3.1 V threshold levels supported by Logic MSO?
