Logic 2.3.1
Logic 2.3.1
Download Links
Check out the Saleae Logic 2 Extension Marketplace!
Read more about the Marketplace on the Saleae blog!
What’s New
  • Added a “reset to default” button to the presets manager
Improvements
  • When saving HLA settings, restart the analyzer if there was a change
  • Updated the terminal library to the latest
  • Reset analog zoom & pan settings when changing between different device types
  • HLA error message now makes it clear when not subclassing HighLevelAnalyzer
Bug fixes
  • Fixed serious crash for Logic 4 users
  • Handle loading a file with missing extensions
  • Handle loading a file with disabled extensions
  • Detect graphic cards that don’t supported webGL
  • Fixed terminal hangup when writing too many characters at once from HLAs
  • (Hopefully) fixed error related to missing device IDs
  • Fixed bug where sometimes extension installs would fail on the first attempt
  • Fixed bug where changing between the original Logic and a new device could break the analog display
  • Improved reporting and handling of internal errors after system sleep/resume
Here are some ideas for the Marketplace
  • Curate the list with recommended extensions.
Capture 2020-06-19 à 10.28.19
Have a look at the implementation of the Visual Studio Code marketplace. Atom list is confused and ultimately
  • Provide tags to group the extensions.
For example, the protocol the extension relies on (I²C, SPI). Also, categories or collections like in the Visual Studio Code marketplace.
  • Allow users to rate the extensions.
The Visual Studio Code marketplace and the Node-RED library have implemented users’ rating.
  • Provide clear information about licensing.
Apart for open source, some developers may want to charge for an extension. Is the marketplace ready for that option?
  • Explain what the PRO label means!
Capture 2020-06-19 à 10.36.35
Please add an option to search for consecutive bytes , mabe like this:
Also, the link to documentation does not work (do not open browser, at least not on Linux)
Screenshot from 2020-07-07 08-34-15
same goes for the “blog-link” in release notes, and links like “repository” and “report” in extensions.
