I have an original Logic (8 channel) purchased in 2014. I’m trying to find the specifications for this hardware but can’t locate anything but generalized descriptions. Is there a link available for this information?
@johngladin57 Our Original Logic datasheet can be found in the link below:
- Logic Datasheet: http://downloads.saleae.com/specs/Logic+Tech+Specs.pdf
Here is the support article containing the datasheets for all of our devices as well:
Hope this is what you needed!
Thanks, I appreciate it. I’m I correct in assuming the 2.* software is what I should use? If not, what 1.* version should I use?
Regards,
JG
Yup, Logic 2.x supports all of our products, including our original Logic. We recommend using 2.x.
Thank you, sir. Have a great day.
