We have a CentOS 7 based compute cluster farm and one of the user wants to use Logic2 binary. I see that CentOS 7 is not listed in the list of OS.
Q1: Is it still possible to run the Logic2 on CentOS 7?
When i try to run the Logic-2.4.9-linux-x64.AppImage directly on CentOS 7 , i get following error-
[puneet@server1]/scratch/puneet/Downloads> ./Logic-2.4.9-linux-x64.AppImage
/tmp/.mount_Logic-WHAuC1 /scratch/puneet/Downloads
The setuid sandbox is not running as root. Common causes:
* An unprivileged process using ptrace on it, like a debugger.
* A parent process set prctl(PR_SET_NO_NEW_PRIVS, ...)
Failed to move to new namespace: PID namespaces supported, Network namespace supported, but failed: errno = Operation not permitted
Trace/BPT trap (core dumped)
Q2: I am unable to understand the message, What is required to run this binary ?.
We extracted the contents of this AppImage using -
./Logic-2.4.9-linux-x64.AppImage --appimage-extract
[puneets@server1]/scratch/puneet/Downloads> cd squashfs-root/
[puneets@server1]/scratch/puneet/Downloads/squashfs-root> ./Logic
[141491:0814/042300.830232:FATAL:setuid_sandbox_host.cc(157)] The SUID sandbox helper binary was found, but is not configured correctly. Rather than run without sandboxing I'm aborting now. You need to make sure that /scratch/puneet/Downloads/squashfs-root/chrome-sandbox is owned by root and has mode 4755.
[puneets@server1]/scratch/puneet/Downloads/squashfs-root> [141493:0100/000000.863005:ERROR:zygote_linux.cc(650)] write: Broken pipe (32)
Q3: I am unable to understand the message again, What is required to run this binary ?.
