First and foremost, thank you for all the hard work that’s being put into Logic 2. It’s become a regular part of my daily work flow.
I wanted to analyze some protobufs in my HLA, but quickly hit upon the issue that I couldn’t import the dependencies required. After going about several methods of adding the packages, I only got to where I wanted after unpacking the AppImage… I doubt that’s a recommended way of going about things.
What is the best way to add third party modules to a new HLAs? Is that just not yet supported?
Thank you for the kind words! We don’t currently have a supported way of installing Python dependencies. This is made harder on Linux, as you discovered, by the fact that the AppImage installs to a separate temporary directory each run.
For an easier workaround in the meantime, you can modify the sys.path in your extension file to include the directory that you installed the Python package to:
import sys
MY_ADDITIONAL_PACKAGES_PATH = '/packages/install/location'
if MY_ADDITIONAL_PACKAGES_PATH not in sys.path:
sys.path.append(MY_ADDITIONAL_PACKAGES_PATH)
import protobuf
Note that ‘/packages/install/location’ is the directory where you installed the packages, not the path to the package itself. So in the protobuf case, it should contain a folder with the name ‘protobuf’ containing the package’s Python files.
An extension that uses the package in this way will unfortunately not work if added to the marketplace at the moment. We’ll likely support installing package dependencies at the extension level either via a standard setup.py or requirements.txt in the future.
Would it work if the user happened to have the packages installed in that location though? That would provide a workaround - just add an instruction to the description/README to make sure the packages are available in that location. Or are you saying that the import would somehow be blocked if the extension were installed through the marketplace?
It should work if the user manually installs the package to that location, though coming up with an install location that will work on Windows and macOS/Linux will be challenging. Extensions installed via the marketplace are configured in the same way as local extensions at the Python level so there shouldn’t be any differences there.
Could the extension.json provide a standard mechanism to specify system path additions specific to the extension? Which would show up in the cfg dialogs?
I needed to use pymavlink for the MAVLink extension I wrote. Here is a little tidbit that automatically imports packages from the user’s site packages (where it would appear if a user ran python3 -m pip install pymavlink)
import sys
import site
user_site = site.getusersitepackages()
if user_site not in sys.path:
sys.path.append(user_site)
from pymavlink import mavutil
This should work on Ubuntu 22. With Ubuntu 24, my plan is to allow the analyzer to have a StringSetting that a user can put in the path to their virtual environment.
Here’s my full workaround at the top of my HLA source:
import os, subprocess, shlex, sys
# --- hack to work around not being able to install 3rd party plugins ---
# https://discuss.saleae.com/t/third-party-libraries-with-hlas/595/7
VENV_DIR = os.path.join(os.path.dirname(__file__), ".saleae_venv")
PACKAGE_NOT_INSTALLED_MESSAGE = f"""ERROR: Saleae venv required for using MY_THIRD_PARTY_LIB.
Please run:
uv venv --clear --python {sys.version_info.major}.{sys.version_info.minor} {VENV_DIR}
source {VENV_DIR}/bin/activate
uv pip install MY_THIRD_PARTY_LIB
deactivate
if not os.path.exists(VENV_DIR):
print(PACKAGE_NOT_INSTALLED_MESSAGE)
raise EnvironmentError(PACKAGE_NOT_INSTALLED_MESSAGE)
try:
# check=False because these calls "fail" when not in the venv, but they still produce the right output...
base_dir = subprocess.run(shlex.split(f"{VENV_DIR}/bin/python -m site --user-base"), check=False, encoding="utf-8", capture_output=True).stdout.strip()
path_to_add = subprocess.run(shlex.split(f"{VENV_DIR}/bin/python -m site --user-site"), check=False, encoding="utf-8", capture_output=True).stdout.strip()
path_to_add = path_to_add.replace(base_dir, VENV_DIR)
print(f"Adding venv {path_to_add}")
sys.path.insert(0, path_to_add)
except Exception as e:
print(f"Hit {e} while trying to figure out what path to add for the venv")
raise e
try:
import MY_THIRD_PARTY_LIB
except ImportError as e:
# --- end 3rd party plugins hack ---
