these messages:
INFO:saleae.automation.manager:sub ChannelConnectivity.IDLE
INFO:saleae.automation.manager:sub ChannelConnectivity.CONNECTING
INFO:saleae.automation.manager:sub ChannelConnectivity.READY
Arnþór
Hi @arnthor,
Thanks for writing in. These messages are produced from our python library. They are logged through the python logger module.
Here is a quick fix:
import logging
logging.getLogger("saleae.automation.manager").setLevel(logging.ERROR)
Note, you should not see these logs by default, they are only shown once you have setup the root logger in your own python with:
logging.basicConfig(level=logging.DEBUG)
or similar.
Ah great, thank you.
Figures that it was something on my end since I spent quite a while searching the internet and the forums and didn’t find any result.
The only relevant result I found for logging.basicConfig was in venv/Lib/site-packages/saleae/saleae.py
logging.basicConfig(level=logging.INFO), I changed it to .ERROR and the messages stopped.
