Cannot capture within a short duration (less than 100 ms)
I would like to capture signals within a very short duration (less than 100 ms). However, whenever I set a small value in the “Stop recording after” setting, e.g., 10 ms, and start capturing, the software always reset the value to 100 ms. Is this a limitation of the software or did I miss something?
Thanks
Oh, interesting. Thanks for bringing this up. It looks like we set the minimum duration limit to 100 ms in the text box for setting the capture duration. I believe this is an intentional limit, but I’ll double check.
In the meantime, you can specify a “Trim data after stopping” value to automatically trim the capture down to 10ms once it’s complete, keeping the most recent data.
Another issue I caught is that, if 100 ms is specified as the “Stop recording after” value, the capture length ends up being a little longer than it.
