Do you have a network connection on your PC?
See the warning:
… looks like you don’t have a calibration file installed for your specific Logic hardware.
You can manually download/install the calibration, following:
If you want a deeper dive into the analog filtering & calibration settings, see this post:
(You can optionally ‘hack’ the calibration file to increase the analog bandwidth / reduce the filtering applied)
However, without any calibration file, you can get strange behavior as described above. In particular, you likely don’t have a mGroupDelay setting that aligns the analog/digital timing for your specific device/filtering settings, nor do you have a mImpulseLength setting that should ‘trim’ the leading analog samples and avoid the behavior you’ve described.
