I figured out you could infer the rising/falling edge by including the ENCA as a data line in the Simple Parallel LLA setup, and using Dual edge rather than Rising edge for clock state:
With this configuration, I believe you can get an X1 or X2 (but not X4) decoder,.
Here’s the beginning of your waveform (t = 0 / trigger: initial incrementing of position):
So, is this more of what you were looking for (other than it cannot do X4, as that would require an LLA)?
Note: For my latest draft, I also modified to use D0 = ENCA and D1 = ENCB (was D0 = ENCB and D1 = ENCA), as that might be more ‘natural’ for new users that hadn’t setup anything before (screenshots above used original mapping):
Dear Bitbob, yes it will work with x2 with reduced resolution. How did you make it counting? I just have 0/1/0 with parallel analyzer. Do you want to share your HLA here, I would like to test it.
… and how it was applied to your capture file (re-saved w/ LLA + HLA added): Session01_6moves-HLA.sal (77.3 KB)
Note: it was based on a ‘locally installed’ HLA (on Windows), from the directory path:
C:\temp\saleae\Quadrature_Encoder
Note: you must be using a new enough version of Logic 2 software that has the ‘Dual edge’ support added in the Simple Parallel LLA. It looks like this was merged into Logic 2 release as of v2.4.4, that was released in Jan, 2023.
Also, for anyone on any other supported platform (MacOS / Linux), the save file probably won’t work unless you remove/add the HLA and install it in your own local filesystem path.
Disclaimer: this is truly a quick draft implementation – no guarantees it would work for anything, other than a basic example of an HLA running on top of the Simple Parallel LLA (download & use at your own risk); please follow-up if it actually works well for you, or if it is actually worth uploading/publishing vs. demo/example only.
Edit:
This draft also has implemented a workaround for displaying ‘0’ on the bubble text, as per other support discussion:
(depending on final feedback on that thread – might want to tweak that solution as well)
