This is more like a feature request. Not sure if this is the right place, but…
When using logic2-mcp, the agent can set a trigger and start a capture. In order to wait for the capture, the agent calls wait_capture(). When the capture is not triggered by the configured trigger event, the call to wait_capture() never returns and the agent is blocked forever.
My request it to add a timeout parameter, so that the agent can set the maximum time to wait. If after that time the trigger event does not happen, then wait_capture() stops the capture and returns with an error (‘timeout’ in this case).
If you don’t want to risk breaking others workflow, this parameter could be optional: when not given (or 0), wait_capture() tool would behave as before (waiting forever). Or you could introduce another tool function: wait_capture_ex(), for example.
It is frustrating to let the agent executing 100’s tests that take hours and when you are back to check the result, the agent is stuck in the second test (because the SUT failed and did not trigger the analyzer).
