Sorry for the delay with this, and sorry for the trouble!
I’ve finished testing 3 different configurations:
- .NET 7, using Grpc.Net.Client
- .NET framework 4.8, using Grpc.Net.Client and both Grpc.Net.Client.Web and WinHttpHandler
- .NET framework 4.8, using Grpc.Core
I’ve found the same findings as you. There is no way to get .NET Framework 4.8 to work with Grpc.Net.Client, presumably because our application does not support TLS.
NET 7 worked just fine with Grpc.Net.Client, and framework 4.8 worked just fine with Grpc.Core.
Unfortunately, that’s all we can offer at the moment. I recommend you continue to use Grpc.Core even after the maintenance period ends in May.
The only alternative would be for us to add support for TLS, not something that we’re currently planning to add.
