# Alpha 11
**URL:** <https://discuss.saleae.com/t/alpha-11/144>\
**Category:** Downloads / Releases\
**Created:** [October 10, 2019, 3:24am UTC](https://discuss.saleae.com/t/alpha-11/144 "2019-10-10T03:24:17Z")\
**Showing post:** 12
**Author:** ![Brian](https://avatars.discourse-cdn.com/v4/letter/b/97f17d/32.png) [@Brian](https://discuss.saleae.com/u/Brian)\
**Post date:** [October 13, 2019, 2:31am UTC](https://discuss.saleae.com/t/alpha-11/144/12 "2019-10-13T02:31:23Z")
One of my frustrations with this version of Logic is that the analog and/or digital channels can not be made “thin” (i.e. taking up very little vertical space). Many times I want the most horizontal data so I span the Logic window horizontally across my 3 monitors. But I also want to see lots of other stuff on my computer at the same time, so I want Logic to take up as little vertical room as possible. But when I start to make the window shorter, instead of scaling (so that all enabled channels are always visible, no matter how short they have to get) it simply allows the very tall channels to scroll off the bottom of the window, so I can’t see them all at the same time! This is very frustrating.
At least with the older 1x Logic software the channels could be made pretty short, although they also scrolled off the bottom of the window if you made the window too short.
I’ll also put in another plug for having some way of seriously minimizing the width of the information on the right and left of the window. Once I have things set up, I don’t need to see the full channel names, or the huge “START” button. I want maximum horizontal space so I can see more of my waveform at once.
Keep at it - the progress in these recent 2.x Logic versions is fantastic. I’m very excited for the future of Saleae!
_[View the full topic](https://discuss.saleae.com/t/alpha-11/144)._
